Cavellino33
Aug 27, 2020Aspirant
Orbi RBR50 dropping WiFi flashing white multiple times/day
Multiple times per day my internet drops and Orbi flashes white. Firmware is v2.5.1.16. My wife keeps complaining as if I’m doing it on purpose. Ha. Please help.
Cavellino33
Aug 28, 2020Aspirant
I changed all the settings as you recommended but the problem persisted. I was nearly ready to go full “office space” on my Orbi when I decide to unplug the satellite. Unplugging the satellite corrected the problem and WiFi signal has not dropped since. Any ideas on why this happened and how to fix. Satellite is now greater then 30ft from rbr50 but still causing problem
Mstrbig
Aug 28, 2020Master
What model is your satellite?
Also try resetting the satellite and repair again. I have found sometimes pairing by pressing the pair buttons does not work correctly. So I generally use the app to pair the satellites. Probably doesn't make a difference, but my personal statistics are 60% on button pushing and 100% on using app.
