Tiemov
Jan 24, 2023Aspirant
Orbi RBR50 drops connection
We have a Orbi RBR50 with 4 connected RBS50's running in our home. For periods they work fine, but the last couple of weeks/months there have been a lot of problems. (Current firmware version is v2.7...
Jan 24, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite ‌‌🛰️
Too Much Wifi: https://youtu.be/UR0viMLISz4
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
