Tiemov
Jan 24, 2023Aspirant
Orbi RBR50 drops connection
We have a Orbi RBR50 with 4 connected RBS50's running in our home. For periods they work fine, but the last couple of weeks/months there have been a lot of problems. (Current firmware version is v2.7...
KevinLiT
Jan 24, 2023NETGEAR Moderator
Hello Tiemov,
Welcome to the NETGEAR Community!
I understand that you are having issues with network stability with your RBR50 FW v. 2.7.3.22. The most recent version for your RBR50 is FW v.2.7.4.24. Please install the latest firmware on your RBR50 then verify network stability.
Please navigate to the link below for the download file for your RBR50:
https://www.netgear.com/support/product/RBK50#download
For more information on manually updating your RBK50 please navigate to the link below:
https://kb.netgear.com/31573/How-do-I-manually-upgrade-firmware-on-my-Orbi-router-using-orbilogin-com
Please keep us informed on the progress of this issue!
Best,
Kevin
Community Team
- TiemovJan 27, 2023AspirantThanks for the reply!
Updated to the latest firmware now. Seemed to work for a day or so, but connection is really unstable again. Sattelites randomly switching to 2.4ghz instead of 5ghz and random drops in connection (less frequent after firmware update)
Got a little better but still not good. Anything else?- CrimpOnJan 27, 2023Guru - Experienced User
Tiemov wrote:
Updated to the latest firmware now. Seemed to work for a day or so, but connection is really unstable again. Sattelites randomly switching to 2.4ghz instead of 5ghz and random drops in connection (less frequent after firmware update)Perhaps it would help to have more detail about the installation. (for example, "floors" are described differently in US and Europe. "ground floor" in Europe is "1st floor in US". "1st floor" in Europe is "2nd floor in US).
When a satellite switches from 5G backhaul to 2.4G backhaul, that is a symptom of the 5G WiFi signal being too weak. Either (a) the distance between router and satellite is too far, or (b) there are hidden obstacles in the radio pathway between them. (I was surprised one time to find that a 1920's house had a brick chimney running up the middle of the house - no longer in use, but still present) Cast a huge "shadow" on the 5G WiFi signal.
- TiemovJan 30, 2023Aspirant
Hi CrimpOn
Yeah I noticed the difference with the "floor" situation when writing my first message. With "ground floor" I mean the "first floor" (US).
I don't think the problem is the distance between the sattelites. The furthest sattelite from the router isn't more than 10-15 meters (11-16 yards??).
I live in the Netherlands, so the hidden obstacles could be relevant. My house (and everbody else's here) is built with bricks. I don't really thinks this is the problem though. I tried playing around with the positions of the sattelites, but it doens't matter in which locations I put them, they switch from 5ghz to 2.4ghz in every position. So it seems that the position isn't relevant in this case. One more thing why I think the obstruction of signal isn't the problem, is that it isn't a constant problem. The backhaul or the sattelite losing connection are totaly random and irregular (sometimes 15 minutes between problems, sometimes 2 hours).
However I'm just a customer, not some kind of expert. So if I'm wrong please let me know
- FURRYe38Jan 27, 2023Guru - Experienced User
Be sure your using a good quality LAN cable between the modem and router. CAT6 is recommended.What is the size of your home? Sq Ft?
What is the distance between the router and 📡 satellite(s)? 30 feet or more is recommended in between RBR and RBS🛰️ to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite 🛰️Too Much Wifi: https://youtu.be/UR0viMLISz4
What channels are you using? Auto? Try Auto and 48 on 5Ghz. Or try setting manual channel 1, 6 or 11 on 2.4Ghz and 40 to 48 channel on 5Ghz.
Any Wifi Neighbors near by? If so, how many?One User Experience/Configuration:
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Got a little better but still not good. Anything else?- TiemovJan 30, 2023Aspirant
Hi, FURRYe38
I sadly don't know the answer to this question and I don't know where to find this...... Idk if this questions only applies if you live in the US?
I stated the situation concerning the materials of my home and the distance between routers and sattelites in my prior reply in this message. But the furthest distance between router and sattelite is 10-15 meters, with 3 more sattelites in between.
Concerning the channels, is Auto and 48 for 5ghz the settings you would recommend. The Channels I'm currently using is Auto and 36 for 5ghz. Would you recommend switchting these?
Yes, in the Netherlands houses are relatively close to eachother. However I haven't had any interference problems in prior situations.
