Tiemov
Jan 24, 2023Aspirant
Orbi RBR50 drops connection
We have a Orbi RBR50 with 4 connected RBS50's running in our home. For periods they work fine, but the last couple of weeks/months there have been a lot of problems. (Current firmware version is v2.7...
Tiemov
Jan 27, 2023Aspirant
Thanks for the reply!
Updated to the latest firmware now. Seemed to work for a day or so, but connection is really unstable again. Sattelites randomly switching to 2.4ghz instead of 5ghz and random drops in connection (less frequent after firmware update)
Got a little better but still not good. Anything else?
CrimpOn
Jan 27, 2023Guru - Experienced User
Perhaps it would help to have more detail about the installation. (for example, "floors" are described differently in US and Europe. "ground floor" in Europe is "1st floor in US". "1st floor" in Europe is "2nd floor in US).
When a satellite switches from 5G backhaul to 2.4G backhaul, that is a symptom of the 5G WiFi signal being too weak. Either (a) the distance between router and satellite is too far, or (b) there are hidden obstacles in the radio pathway between them. (I was surprised one time to find that a 1920's house had a brick chimney running up the middle of the house - no longer in use, but still present) Cast a huge "shadow" on the 5G WiFi signal.
- TiemovJan 30, 2023Aspirant
Hi CrimpOn
Yeah I noticed the difference with the "floor" situation when writing my first message. With "ground floor" I mean the "first floor" (US).
I don't think the problem is the distance between the sattelites. The furthest sattelite from the router isn't more than 10-15 meters (11-16 yards??).
I live in the Netherlands, so the hidden obstacles could be relevant. My house (and everbody else's here) is built with bricks. I don't really thinks this is the problem though. I tried playing around with the positions of the sattelites, but it doens't matter in which locations I put them, they switch from 5ghz to 2.4ghz in every position. So it seems that the position isn't relevant in this case. One more thing why I think the obstruction of signal isn't the problem, is that it isn't a constant problem. The backhaul or the sattelite losing connection are totaly random and irregular (sometimes 15 minutes between problems, sometimes 2 hours).
However I'm just a customer, not some kind of expert. So if I'm wrong please let me know
