Tiemov
Jan 24, 2023Aspirant
Orbi RBR50 drops connection
We have a Orbi RBR50 with 4 connected RBS50's running in our home. For periods they work fine, but the last couple of weeks/months there have been a lot of problems. (Current firmware version is v2.7...
Tiemov
Feb 01, 2023Aspirant
I'm almost certain that the problem of the sattelite switching from 5ghz to 2.4ghz has to do with the multiple smart devices in my house (A/C, camera, etc.). Could this be the case?
The smart devices show up in the 2.4ghz section and for example my laptop in the 5ghz section. However this seems to switch all devices to 2.4ghz as my download speed declines from 40-50MBps to 800KBps. I don't know why this is the case and I don't know how I'm able to fix this issue.
Do you have any clue?
Small update: I don't know what happened, but since yesterday morning I haven't noticed any disconnects. I'm not convinced it is fixed though. This has happened a couple of times, but after a few days it goes back to the bad situation
KevinLiT
Feb 01, 2023NETGEAR Moderator
Hello Tiemov,
Please check your PM.
Best,
Kevin
Community Team
