smetsch
Jul 13, 2020Aspirant
Orbi RBR50 Extender Compatibility
In 2018, I bough an RBR50 with two RBS40 extenders. With all the work from home in my future, I want to add another extender. It seems very hard to find any extenders compatible with this setup tha...
Jul 13, 2020Guru - Experienced User
If it's a long house you could possibly do a Daisy Chain, however that might be moving the RBR.
I have same size home, rectangular as well mostly. 2 story with basement. However my modem and RBR are up on 2nd story at one end and the RBS is down the basement, wireless or wired. about 30-40 feet away. I do have a 2nd RBS in a 1st level dining are thats off to one side towards the back of the house. Its about 25-30feet as the crows flys.
I guess since your RBR is the the middle that you have the RBS on either side of the RBR?
What is the distance between the router and satellite(s)?
You can try a EX3700 or EX7700. Something to ask NG support about getting FW to make either one of these work. IF these are in stock someplace.
smetsch
Tough to measure the distance because there ae a lot of walls! I really think I just need another satellite, but I can't find them for sale anywhere! That is why I was thinking a generic extender.
- FURRYe38Jul 13, 2020Guru - Experienced User
Buliding materials will be problematic for satellites and extenders as well.
You might try something and see if it will connect. if it doesn't then return it. Find a place with a good refund policy.
