suared
Mar 26, 2022Tutor
Orbi RBR50 Factory Reset doesn't work! (no screen access)
Looking through all the forums and none seem to solve my issue though I am with the 1 person that said they were about to throw the network in the garbage! Here is what I am running into: Initial I...
- Mar 26, 2022
Did you try nmrpflash? https://github.com/jclehner/nmrpflash
The other thing is usually you can find used/renewed rbr50's on ebay/amazon because people will buy the kit for the extra satellites because its cheaper to buy the kit. Might be an option if you can't get it.
If the hardware is good on the device, usually tftp/nmrpflash doesn't error out during the writing process. it might be way you're getting the corrupt firmware is because something in the chip is bad. But you can always try it
suared
Mar 26, 2022Tutor
Go figure - once peak frustration hit and I submitted a question the color on the ring changed out of the blue and it just started working again! Not sure what worked so listing here what we did in case it helps other troubleshoot:
* I had unplugged the router fully for 3 days from the last round of attempts - my logic there was maybe if something was stuck that depended on battery it would die and maybe accept the reset
* I had done that reset cycle, 30 seconds+ multiple times - this is what I think eventually worked and if that was it, it means that after a 30second reset hold you ALSO then need to not expect any changes for 5+ minutes before it randomly changes color and starts accepting changes
If Netgear support sees this I would suggest:
* the reset button should work per the instructions - 7 seconds vs. 30
* a light should notify you if the reset was accepted somehow (e.g. fast blink, diff color, other) - so that you know it is doing "something" and not that it is still in the same state
