FrankGoedschalk
Dec 16, 2019Aspirant
Orbi RBR50 firmware 2.3.5.30 is all of a sudden blocking an internet site
Community, All of a sudden my Orbi blocks some internet sites, when I use my vpn then is evrything oké. I'm ussing a macbook and untill 2 days ago everything was working normal. Where can I ...
- Dec 16, 2019
Hi Plemans,
I was using cloudfare and changed it now to the default dns server and solved my problem
Thanks
Dec 16, 2019Guru - Experienced User
1. what modem are you using?
2. have tried change the default DNS provider from your isp's provider to something like google or cloudfares?
googles: 8.8.8.8 or 8.8.4.4
cloudfare 1.1.1.1
- FrankGoedschalkDec 16, 2019Aspirant
Hi Plemans,
Thanks
- plemansDec 16, 2019Guru - Experienced UserGlad to hear it! If you mark it as solved, it might help the next person with this issue.
