Peyerman
Jun 03, 2018Follower
Orbi RBR50 firmware check fails multiple times
Tried RBR50 for firmware updates multiple times through the Orbi App via Settings —> Router Settings —> Check for Updates . Currently on version 2.1.4.10.
App tried checking, says it may take 5 minutes, cheeks for roughly 10 seconds, then says “There was a problem checking firmware update”. If I try multiple times, “Try again”, it will finally come back and say I am up to date.
1 Reply
I presume if it's getting some results, your ok. I believe the v.10 is most current on the update servers. If you wanting to get more accurate results and compare whats available, try looking at the support site web page for what is currently available for your model Orbi.
