Bafta's avatar
Bafta
Tutor
Dec 22, 2022
Orbi rbr50 firmware update
Not able to update firmware via app, comes up with errors. When I do it manually via modem portal address it is telling me firmware version is not valid even through it is correct. ORBI RBR50 modem & ...
  • plemans's avatar
    Dec 22, 2022
    What firmware version are you on?
    what firmware version are you trying to install?
    There are 2x versions of that 50 series, do you have the correct one?
    did you extract it prior to trying to manually upload it?
