Bafta
Dec 22, 2022Tutor
Orbi rbr50 firmware update
Not able to update firmware via app, comes up with errors. When I do it manually via modem portal address it is telling me firmware version is not valid even through it is correct. ORBI RBR50 modem & ...
- Dec 22, 2022
What firmware version are you on?
what firmware version are you trying to install?
There are 2x versions of that 50 series, do you have the correct one?
did you extract it prior to trying to manually upload it?
KevinLiT
Dec 23, 2022NETGEAR Moderator
Hello Bafta,
Welcome to the NETGEAR Community!
The current firmware for the RBR50 and the RBS50 is firmware version 2.7.4.24. If the satellite is already on the current version there is no need to update the satellite first.
Please use the link below for the compatible firmware version for your RBR50:
Orbi RBR50 | WiFi System | NETGEAR Support
Please use the link below for the compatible firmware version for your RBS50:
Orbi RBS50 | WiFi System | NETGEAR Support
Best,
Kevin
Community Team
Bafta
Dec 27, 2022Tutor
Thank you. All fixed now
- FURRYe38Dec 27, 2022Guru - Experienced User
