insecticide
Oct 04, 2018Tutor
Orbi RBR50 Firmware V2.2.1.210
Recently saw a firmware update to V2.2.1.210 and tried it. The orbi now shows an invalid certificate. Rebooted the Orbi and computer...no joy.
Anybody else see this behavior?
Oct 04, 2018Guru - Experienced User
is this from the update UI or manual file download and install?
What browser are you using?
I recommend downloaded the recent files to your PC and use IE11 or FF browser to install them...Then factory reset everything and set up from scratch...
insecticide
Oct 04, 2018Tutor
Updated from the Web UI. Browser is Safari (mojave os).
- FURRYe38Oct 04, 2018Guru - Experienced User
I recommend downloaded the recent files to your PC and use Safari or FF browser to install them...Then factory reset everything and set up from scratch...
- insecticideOct 04, 2018Tutor
This problem only occurs if you try to use https instead of http of course. Yeah call me crazy for using https. The certificate used in the firmware or the https listener is appraently bad or misoncfigured. That's a bug.
Use HTTP for now...
I believe NG may not support HTTPS while on the LAN side of the router connecting to its UI. Not a security measure.
