Ninjahedge
Jun 06, 2020Guide
Orbi RBR50 Frequently disconnecting/reconnecting to the Internet
I recently (February) bought the Orbi RBR50 from Costco to replace a rather expensive gaming router that needed to be power cycled every few days because it could not keep up with all the smart-home ...
mhbethany
Aug 04, 2020Aspirant
YES! I have th exact same problem. Our TV and Apple TV have pop ups that show each time internet was dropped. It happens multiple times per day and comes back quickly. But using apps like Sling and HBO Max, we get booted out and have to restart our program each time. It's SO frustrating.
Also connected to Verizon Fios router with its WiFi signals turned off. Orbi in AP Mode. Happens either via WiFi or wired connection to Orbi satellites. RBR40 Orbi.
Aug 04, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
mhbethany wrote:YES! I have th exact same problem. Our TV and Apple TV have pop ups that show each time internet was dropped. It happens multiple times per day and comes back quickly. But using apps like Sling and HBO Max, we get booted out and have to restart our program each time. It's SO frustrating.
- NinjahedgeAug 05, 2020Guide
Update.
I tried with just the Verizon Router, worked fine.
What I did last was use my old setup. I do not have it as AP, I have it setting up its own IP address chain and then connecting to the Verizon router. It does not drop anymore, but there is a down side.
I have the Net Server hooked to the Orbi. Works great if you hard wire to the Orbi or use one of its wireless signals. You CAN'T connect to it if you wire or link to the Verizon router.
Same exact problem I had last time with my previous router.
I was hoping I did not have this problem again, but back to the start.
(I am guessing it is an IP assignment glitch that causes a conflict. NONE of the remote items have been having a problem with this since I went back to the old setup...)
- FURRYe38Aug 05, 2020Guru - Experienced User
If the ISP modem/ONT already has a built in router, This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
https://kb.netgear.com/26765/Disabled-Features-on-the-Router-when-set-to-AP-ModeYou can try option #2 first and see if this helps any.
Ninjahedge wrote:Update.
