Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
Cenex22
Thanks for all the assistance and recommendations. I checked out the reddit thread, and it's bizarre to think this could somehow be related to the time change. But the common thread seems to be that this just inexplicably started recently for numerous people.
Anecodotal reports are sparse, but it almost sounds like a factory reset and/or loading a previous firmware version isn't going to help. I will still try that tonight, but I won't remain optimistic that it will help.
Mar 15, 2021Guru - Experienced User
Let us know if checking the NTP settings helps. We just went thru the time change and RBR should have tracked this. Saw others posting that NTP settings maybe effecting this. Seems that v104 has been working for DNS then all of a sudden had problem in DNS just recently.
Cenex22 wrote:Thanks for all the assistance and recommendations. I checked out the reddit thread, and it's bizarre to think this could somehow be related to the time change. But the common thread seems to be that this just inexplicably started recently for numerous people.
