Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
jimih
Mar 15, 2021Tutor
I was looking at downgrading to older firmware, but since the current version (claims to) include security updates, I am hesitant.
I think the "reset the DNS settings" is easy enough for a short term before I look for another solution / product / vendor.
vajim
Mar 16, 2021Master
jimih wrote:I was looking at downgrading to older firmware, but since the current version (claims to) include security updates, I am hesitant.
Roll your firmware back. You and your network will be find
