Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
JJ126
Mar 21, 2021Guide
System became totally unstable due to .104 software which was written by a top moron.
Fix is stop using netgear NTP server.
Use time.google.com instead.
You cannot use the App for this either, use a web browser on your iPad or laptop.
The App is completely useless. Probably written by the same moron who wrote the .104 code.
It's a pity crap software makes such a potentially nice system totally worthless.
- FURRYe38Mar 21, 2021Guru - Experienced User
Also don't use Traffic Meter was one report that NG seemed to acknowledge by NG to one user was the cause of this problem. Others reported seeing same and having better results after it was disabled. Good Luck.
JJ126 wrote:System became totally unstable due to .104 software which was written by a top moron.
