Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
hankster42
Mar 22, 2021Aspirant
I've been experiencing similar issues since the same firmware release was loaded. The only way I've been able to restore access to the internet, is to login to my Orbi, Select "Internet" then click the "APPLY" button. Within a minute everything comes back online.
r0b0tvampire
Mar 22, 2021Star
You can use this for options to work around the issue (Option I is probably the one you want):
https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
- hankster42Mar 24, 2021Aspirant
I disabled the Traffic Meter as suggested and my network has been stable for 2 days now. Seems to have done the trick. Thanks!
