Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
jimih
Mar 22, 2021Tutor
Glad it worked out for you, but my configuration had NTP using time.nist.gov and two openDNS static servers configured when I started experiencing the failures.
My guess is that by changing your NTP settings you actually forced the router to reset its network stack.
Mar 22, 2021Guru - Experienced User
