Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
JJ126
Mar 24, 2021Guide
Yes but you have to do this every hour...very unstable.
hankster42 wrote:I've been experiencing similar issues since the same firmware release was loaded. The only way I've been able to restore access to the internet, is to login to my Orbi, Select "Internet" then click the "APPLY" button. Within a minute everything comes back online.
Yes but you have to do this every hour and it ain't stable.
Just disable Trafic stats and point NTP to stable NTP instance.
US Navy is solid.
Mar 24, 2021Guru - Experienced User
Only thing you have to do is disable Traffic Meter. You can enable DST and either use NGs time server or something else. You don't have to do this every hour. Once TM is disabled. All will work normally.
- bmfelderMar 24, 2021Initiate
Thanks for sharing this info. I made the changed. I will see how it goes.
This is interesting. Firmware check service unreachable.
Netgear fix it.
