Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
r0b0tvampire
Mar 22, 2021Star
You can use this for options to work around the issue (Option I is probably the one you want):
https://www.reddit.com/r/orbi/comments/m5l3vk/orbi_dropping_dns/
hankster42
Mar 24, 2021Aspirant
I disabled the Traffic Meter as suggested and my network has been stable for 2 days now. Seems to have done the trick. Thanks!
