Cenex22
Mar 15, 2021Initiate
Orbi RBR50 frequently losing connection
I've had the Orbi RBR50 for nearly 2 years with no issues. Just a couple days ago, however, it has suddenly started losing connection several times a day. The connection is fine when I connect my P...
MrTWA
Mar 26, 2021Aspirant
I had a message above where I was having this issue. What finally brought stability to my system was to uncheck the adjust for daylight savings time box and to move ahead my time zone by one hour. This was suggested by someone else. I do not have traffic monitoring on, so I suspect if you turn off traffic monitoring and address the daylight savings issue you might see some stability.
