Rshotok
Feb 05, 2020Aspirant
Orbi RBR50 hanging after reboot
About a week ago I updated to the latest firmware available (2.5.1.8). The network and mgt app seemed to be responding slowly, so I tried to reboot the router. Now it just pulses white and never fini...
Feb 05, 2020Guru - Experienced User
Rshotok
My internet provider is Comcast, but that is not the issue as I can connect my laptop directly to my Comcast modem and it works. And it was working fine before the reboot, albeit performance seemed to be degradating, which is why I rebooted.
i saw nothing in the readme about a factory reset after the upgrade (it simply said refer to the OM), but I can't get it to reset now as I've tried holding in the reset button after it hangs. It goes amber and appears to reset, but never finishes booting.
- FURRYe38Feb 05, 2020Guru - Experienced User
So disconnect the RBR from the ISP modem. Disconnect ALL other devices from the RBR accept for 1 wired PC. Press the back reset button for 15 seconds then release. The top ring LED should flash WHITE for a bit, then slowly pulsate WHITE, then turn PINK. Can you get to this point?
- RshotokFeb 05, 2020Aspirant
Here is my ISP (xfinity) router info:
Model: CGM4140COMVendor: TechnicolorHardware Revision: 2.2I tried the reset, but no go. Here is what is happening- power on, white ring pulsing quickly- pulsing changes to slow white, laptop given IP via DHCP- hold in reset- power light solid amber- power light flashing amber after about 7 seconds- let go of reset after 15 seconds- power light, no light- The white ring on top is still slow pulsing white, my laptop is retaining the original address, and the router is also retaining the original address verified with pingQuestion, why is the reset required after the firmware upgrade and why wasn't that in the readme?Thanks,
Bob- FURRYe38Feb 05, 2020Guru - Experienced User
So can you access the RBRs web page at 192.168.1.1?
Resetting the RBR will always keep the default IP address of 192.168.1.1.
If you only have 1 wired device connected then it's IP address probably won't change either.
Be aware that your ISP modem already has a built in router. This would be a double NAT condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
