E14dtl
Aug 11, 2020Follower
orbi rbr50 how many devices does it holdbi
how many devices can I add onto my orbi. I have a virgin media hub that holds 15 devices( currently has 30 on it). I bought the orbi hoping that I can split the devices between the 2 routers. my q...
Aug 11, 2020Guru - Experienced User
https://kb.netgear.com/31097/How-many-devices-can-my-Orbi-system-support
Having two routers online is NOT recommended. This would be a double NAT (two router) condition which isn't recommended. https://kb.netgear.com/30186/What-is-Double-NAT
Couple of options,
3. Or disable all wifi radios on the modem and connect the Orbi router to the modem, configure AP mode on the Orbi router. https://kb.netgear.com/31218/How-do-I-configure-my-Orbi-router-to-act-as-an-access-point and https://www.youtube.com/watch?v=H7LOcJ8GdDo&app=desktop
