nonilex
Feb 15, 2019Guide
Orbi RBR50 how to prioritize devices
Is there a way to prioritize the various devices using the Orbi RBR50’s and it satellite’s WiFi signals? There are certain devices we have that are more important that others (e.g. home office compute...
ekhalil
Feb 15, 2019Master
nonilex wrote:
......... the stronger signal 5Ghz instead of the weaker 2.4Ghz?
In fact, the 2.4 GHz signal is usually stronger than the 5 GHz because the lower the signal frequency the lower the attenuation. You are probably refering to the capabilities of the band not signal strength! :)
It's always the device who chooses which band to connect to, not the AP (Orbi).
Only few device types allow you to choose your prefered band. In Wndows computers, most of the wifi drivers have settings to prefer 5 GHz or 2.4 GHz.
On the other hand, in Orbi there is a feature called Band Steering, which will always try to steer 5GHz-capable devices to connect to the 5GHz band, provided that the device has previosly successfully connected to the 5 GHz band.
