Shazw1
Dec 18, 2020Follower
Orbi RBR50, I’m still having drops in signals in parts of the house.
Recommendations to improve this. I tried to call sales for a recommendation but I was on the phone for an hour and got passed around. Hoping I can a solution here.
Dec 18, 2020Guru - Experienced User
I
What is the distance between the router and satellite(s)? 30 feet or more is recommended in between RBR and RBS to begin with depending upon building materials when wirelessly connected.
https://kb.netgear.com/31029/Where-should-I-place-my-Orbi-satellite
https://eyenetworks.no/en/wifi-signal-loss-by-material/
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
