thomaspmaher
Mar 22, 2021Follower
Orbi rbr50 I get error trying to check for new firmware
jeberhawk
Mar 23, 2021Tutor
Same problem for me. Here’s a screenshot.
- vajimMar 23, 2021Master
don't use the app
login to your Orbi via PC
- jeberhawkMar 23, 2021Tutor
vajim Thank you. The RBR50 router has the latest firmware version; V2.7.2.104. I typically use an iPhone to check for firmware updates. I suppose this time the app for Apple has the fireware check error problem.
jeberhawk wrote:vajim Thank you. The RBR50 router has the latest firmware version; V2.7.2.104. I typically use an iPhone to check for firmware updates. I suppose this time the app for Apple has the fireware check error problem.
keep an eye on V2.7.2.104
do a search here.....lots of folks talking about it was as well as the moderators
- jeberhawkMar 26, 2021Tutor
The Netgear Team updated their Orbi app for iOS and fixed the "Firmware Check Error" checking firmware update problem for my RBR50 router. I can now check for an update without using my laptop.
