ipswichclam
Jun 25, 2019Aspirant
ORBI RBR50 in AP mode; can I use ethernet backhaul via coax MOCA?
I just switced my Orbi to AP mode to avoid double NAT issues with an existing Engenius outdoor AP. I want to try Ethernet backhaul with one of the satellites which is physcially far from the othe...
Jun 25, 2019Guru - Experienced User
What happens if you disable Daisy Chain, save settings and reboot the entire system. I'd give 5-10 minutes for the system to settle down. Then test again.
