Mr5858
Dec 27, 2019Follower
Orbi RBR50 in AP mode with ethernet backhaul
Hi there, I am using RBR50 in AP mode connected to 1 satellite using ethernet backhaul and this is the situation: 1.- If I connect the RBR to my router using the wan port, the satellite will ...
Dec 27, 2019Guru - Experienced User
Mr5858 wrote:Hi there,
1.- If I connect the RBR to my router using the wan port, the satellite will not connect, I would need to connect another ethernet cable to the lan port of the RBR50.
2.- If I connect the RBR50 to my router using the lan port instead, then the red light on the RBR50 will never go out.
Is this a normal behaviour ?
Thanks
