QL
Jul 29, 2022Tutor
Orbi RBR50 in AP mode
Hi there, I use Orbi RBR50 in AP mode, only for WIFI. It got IP 192.168.1.3 from my regular router (192.168.1.1). Wifi on regular router is already disabled. Say, I have 2 computers. PC A is ...
CrimpOn
Jul 29, 2022Guru - Experienced User
The Orbi in Access Point mode does not perform DHCP and assign IP addresses.
- QLJul 29, 2022Tutor
that's weird. Then how come my wireless laptop got this 10.0.0.12 IP? Clearly Orbi in AP can do DHCP.
thanks.
apologize, I double checked, it's indeed in router mode. I need to do some config change, It should be in AP mode......
- michaelkenwardJul 30, 2022Guru - Experienced User
The clue is in that address. It is a classic sign of "double NAT". Two routers on one network. If router 2 finds another router it will often default to that address range. That address is often an indicator that someone has slapped a router behind a modem/router.
Some Manuals carry this helpful warning;
Note: If the router detects a conflict with a WAN IP address, it changes its IP address to 10.0.0.1 or 172.16.5.1.
In your case, the conflict is router plus router.
- KevinLiTAug 01, 2022NETGEAR Moderator
Hello QL,
Welcome to the NETGEAR Community!
When there are two routers connected in a network one of the routers will automatically change its network to avoid network conflicts. If you would like to have all devices on the same DHCP scheme then all devices will have to be connected to the Orbi. However, the best method to avoid this will be to put your RBR50 in AP mode.
Best,
Kevin
Community Team
