QL
Jul 29, 2022Tutor
Orbi RBR50 in AP mode
Hi there, I use Orbi RBR50 in AP mode, only for WIFI. It got IP 192.168.1.3 from my regular router (192.168.1.1). Wifi on regular router is already disabled. Say, I have 2 computers. PC A is ...
QL
Jul 29, 2022Tutor
that's weird. Then how come my wireless laptop got this 10.0.0.12 IP? Clearly Orbi in AP can do DHCP.
thanks.
apologize, I double checked, it's indeed in router mode. I need to do some config change, It should be in AP mode......
michaelkenward
Jul 30, 2022Guru - Experienced User
The clue is in that address. It is a classic sign of "double NAT". Two routers on one network. If router 2 finds another router it will often default to that address range. That address is often an indicator that someone has slapped a router behind a modem/router.
Some Manuals carry this helpful warning;
Note: If the router detects a conflict with a WAN IP address, it changes its IP address to 10.0.0.1 or 172.16.5.1.
In your case, the conflict is router plus router.
