Guex
Dec 01, 2020Follower
Orbi RBR50 installation problem
Hi, I purchased this Orbi, recommended by a friend, to help with current slow internet. I currently have a modem that I lease from Centurylink - which is my provider. I was told I could r...
TAZSwade
Jan 31, 2021Aspirant
Question on top of what has already been answered...again...laymen.
So I have fiber coming to my house, but CAT5 from wall to current Netgear router (no modem)...everything operating at full speed with all my tests and service provider tests. I was told to just unplug from current router and go into Orbi.
I thought the Orbit was a router and modem all in one?
thanks for any input.
Guex wrote:Hi,
I was told I could replace this router with the Orby router, but when I tried to install it, it tells me to connect it to my current modem., which I did. However, now nothing works.
My question: can the Orbi router replace the current modem and be a stand-alone or do I need a modem in addition?
I am a layman and need help desperately. Anybody please?
Thank you inadvance.
Helena
Do I still need a modem with this fiber-to-CAT5 to Orbi?
Obi-La
Jan 31, 2021Guide
A modem is a Modulation-Demodulator meaning it converts the fiber light signals to an IP signal the input to your router operates with and connects to. Fiber/glass to copper wire. A router is like a splitter, or think of it like an office phone system, where you have one incoming phone line/number but several extensions that can connect to that one incoming line, except with a router and data the sharing happens very fast, effectively simultaneously to all the extensions. Can you post the make & model of the CenturyLink box you have, I can look it up and see what it is, a modem-router, or just modem, and if it also does WiFi.
