A1406
Mar 10, 2021Tutor
Orbi RBR50 intermittently dropping internet connection
Hello, I am having issues with my RBR50 intermittently dropping our internet connection. It seems the router might be restarting at what seem like random times causing a WiFi disruption. I've looked...
vajim
Mar 10, 2021Master
Get rid of 2.7.2.104
lots of problems
- A1406Mar 10, 2021Tutor
vajim wrote:Get rid of 2.7.2.104
lots of problems
The issue occured prior to the firmware update, so while that could be contributing factor, it's likely not the root cause.
Or is there a way to confirm it's the firmware causing the issue? Is there a more stable version I should download and apply? Does netgear even give access to previous firmware versions?
- vajimMar 10, 2021Master
lots of problems
Go to the download section here and enter your model number.
do a search here on 2,7.2.104. Lots of complaints
vajim wrote:
lots of problems
I've found where I can download previous firmware versions. Is there a version I should apply that is generally accepted as stable?
