A1406
Mar 10, 2021Tutor
Orbi RBR50 intermittently dropping internet connection
Hello, I am having issues with my RBR50 intermittently dropping our internet connection. It seems the router might be restarting at what seem like random times causing a WiFi disruption. I've looked...
Mar 10, 2021Guru - Experienced User
Please try a factory reset and setup from scratch with the RBR and RBS.
A1406 wrote:Hello,
I am having issues with my RBR50 intermittently dropping our internet connection. It seems the router might be restarting at what seem like random times causing a WiFi disruption. I've looked into the logs, but a restart also seems to erase all log entries prior to the restart. The connection is restored after the RBR50 reboots. I updated the firmware to the most current version (2.7.2.104) and this did not fix the issue.
Any advice on how to continue troubleshooting?
- A1406Mar 10, 2021Tutor
FURRYe38 wrote:What is the Mfr and model# of the Internet Service Providers modem/ONT the NG router is connected too?
A1406 wrote:Hello,
I have fiber optic service through Sonic and the modem was installed in a way where I cannot see the mfr/model#. I will have to reach out to them for this info.
I will try a factory reset and setup from scratch.
- FURRYe38Mar 10, 2021Guru - Experienced User
Ok, only checking to see if there is a router at the modem or not. These can be problematic.
Have the ISP check the signal and line quality UP to the modem. Be sure the ISP provisions the modem correctly.
- vajimMar 10, 2021Master
A1406 wrote:Hello,
Keep an eye on that firmware
