A1406
Mar 10, 2021Tutor
Orbi RBR50 intermittently dropping internet connection
Hello, I am having issues with my RBR50 intermittently dropping our internet connection. It seems the router might be restarting at what seem like random times causing a WiFi disruption. I've looked...
A1406
Mar 10, 2021Tutor
I havn't yet had a chance to factory reset and re-setup the RBR50, but something happpened last night that could provide some insight.
I was playing Xbox (which is hardwired to the RBR50) and the internet connection dropped/I was disconnected. The RBR50 LEDs then went to solid white, stayed solidly lit for a bit, then went to pulsing white. The connection was then reestablished.
Does the fact that a hardwired peripheral lost connection and the LED info/behavior provide any clues?
vajim
Mar 10, 2021Master
if you're still running 2.7.2.104 it might
