myfathersson
Oct 09, 2017Aspirant
ORBI RBR50 Internet Connection keeps Dropping
Hi, Model: ORBI RBR50 w/ 1 sat Firmware: V2.0.0.74 OS: Win7, Android First, I appologize for starting yet another thread on this subject. Second, I'm not a network expert...know enough to b...
aaz
Oct 09, 2017Virtuoso
Sounds like you have two routers inline to each other. You should either change the ISP router to a Bridged modem mode (ask your ISP) that will make the Orbi the router, or change the Orbi to AP mode.
Since my ISP router was causing issues before that required a reboot daily pretty much I personally set the ISP to bridged, and the Orbi as the router. My connection has been rock solid for the last month with no unscheduled disconnects.
- myfatherssonOct 09, 2017Aspirant
aaz,
Thanks so much for the reply. You are correct, a detail I failed to mention in my original submission is that the both the ORBI and the modem are acting as routers. After submiting my message I stumbled across a site where the disconnect issue was cleared up by setting the ORBI in AP mode, which I've had just done before you message arrived. I'll see if the simple solution works. If not, then I'll look into following your suggestion.
Again, thanks very much. You've been very helpful
Peter
- myfatherssonOct 22, 2017Aspirant
Update: Still dropping after setting Orbi in AP mode. I'll try setting the modem/router to bridge mode and the Orbi back to router. Will also try rebooting everthing before changing modes. Never know, may help.
Will update later with results.
- dxNov 16, 2017Aspirant
Hi myfathersson,
Curious if your Orbi issue is resolved? I'm facing the same problem and have an identical setup, firmware version as you do.
Thanks,
DX
