Anonymous
Aug 05, 2019Orbi RBR50 Internet Port Dead?
Randomly tonight, the Orbi went out. When I checked the connection to the Comcast modem, the lights were not active/lit up for the connection from it to the Orbi. I connected a VPN router and th...
Aug 06, 2019Guru - Experienced User
Is it just the WAN port or all ethernet ports?
Here's what i'd start with.
1. You've tried the factory reset. Great.
2. Try a new cable. Maybe something is wonky. :)
3. Try reloading the firmware. Manually install the firmware (possibly try 1 version older) and reset it afterward. Make sure to do it over a hardwired connection
4. If it didn't work, maybe something did fry the port. If you're not still within your warranty period, there is the option to mirror the wan port to lan port 1. go to 192.168.1.1/debug.htm (or whatever your orbi's ip address is) and check off the mirror wan port option.
Anonymous
Aug 06, 2019Thanks for the feedback!
I've tried multiple cables--they were associated with the different devices and I was not clear there. I also cannot connect to the device to get on its wifi, so we're now at the replacement phase, which means there's a resolution, at least.
Thanks again!
- plemansAug 06, 2019Guru - Experienced UserIs the light on the orbi on? You could try tftp to reinstall firmware.
https://kb.netgear.com/000059634/How-to-upload-firmware-to-a-NETGEAR-router-using-Windows-TFTP- CrimpOnAug 06, 2019Guru - Experienced User
It is really annoying that Netgear "saved a dollar" by not putting connection and activity lights on the ethernet jacks.
- FURRYe38Aug 07, 2019Guru - Experienced User
I miss the days of having LED on the ports in back of routers. So nice to know that there is activity or not. Mfrs gotta save money somewhere. :smileyfrustrated:
