nonilex
Jan 08, 2019Guide
Orbi RBR50 iOS disconnection issue
ORBI RBR50-V2.2.1.210 constantly disconnects iOS devices. This is similar to an old “solved” post that is closed. But the issue is current and the solution ineffective as the firmware update that solv...
- Feb 15, 2019Problem solved!
Changes I made
On orbilogin.com on the Advanced tab under advanced setup wireless settings
Set 2.4Ghz channel to 1
Disabled daisy chaining since I only have 1 satellite.
Enabled beam forming to boost device WiFi reliability.
Changed CTS/RTS to long preamble mode
2.4 GHz and 5 GHz (2341 and 2345 respectively), changed preamble modes to long preamble, and Set 20/40Mhz Coexistence to 40Mhz only
2.4Ghz wireless power under Advanced Tab/Advanced Settings/Wireeless and set it at 25%.
* Undid this last one as it made it tricky when multiple devices were using WiFi.
* Kept all other settings changes as described above.
Resolved problem.
Thank you FURRYe38 got all the help!
P95357
Mar 03, 2019Guide
Thanks for this. It solved my connection issues as well. After reading all old 2017 and 2018 posts referring to a solution that didn’t solve my problem, I came to your post and it did the job.
In my setup I have the main hub wired to 2 satellites and an 8-port switch, distributing wireless and wired Internet around the house.
After some set up issues I was able to connect all devices to the Orbi WiFi network and have reliable and fast internet in all devices except iPhones.
More interestingly, while connected, on some iPhones I wouldn’t have internet at all and on others the YouTube app would work but it wouldn’t fetch new emails, for example. Or you could search Google, see the results of the search but clicking in any of the results would return an error message of “connection issues”. It drove me crazy for about two weeks until I found this.
Before the Orbi, I had purchased a Linksys Velop system but it didn’t work at all. Over the course of 10 days, I had decent internet during a few hours only and spent countless hours with their support on the phone setting it up and rebooting over 50 times. As a measure of despair, I then purchased the Orbi and was having issues as well. This Velop system has been now returned in favor of the Orbi.
After following your recommendations, Orbi has been working flawlessly for the past 3 days. After all the ups and downs with both Velop and Orbi, I’m cautious to declare it a win but it does certainly look like a win.
Thank you again.
Thank you again.
