JEFF507
Aug 11, 2019Follower
Orbi rbr50 IOS Mojave and USB printer
I am trying to install my Brother MFC 7420 USB printer on my Orbi router. I am using a Mac running Mojave OS. The Mac and the printer have run well together over a different network prior to the Or...
Aug 12, 2019Guru - Experienced User
I recommend you contact NG support and ask them for help on this. Possible that the app isn't supported on Mojave or there is a problem with it.
https://www.netgear.com/mynetgear/registration/login.aspx
Good Luck
