ChuckieCheese
May 05, 2020Luminary
Orbi RBR50 is not detecting new firmware Version 2.5.1.16)
Per Netgear website, there is a new firmware https://kb.netgear.com/000061838/RBR50-RBS50-Firmware-Version-2-5-1-16 My RBR50 currently have V2.3.5.34. When I login to the router --> Firmware Upda...
CrimpOn
May 05, 2020Guru - Experienced User
ChuckieCheese wrote:Is 2.5.1.16 not the right firmware for my RBR50?
The answer is, "it depends". If your Orbi is not functioning correctly, new firmware has addressed some problems. But, new firmware often introduces new problems. So, if the Orbi is functioning the way you want, there is no need to update the firmware. When there is an urgent requirement to update firmware, the hope is that Netgear will make that need abundantly clear.
