Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
Jul 11, 2019Guru - Experienced User
Ran some WAN to LAN speeds tests with v30 loaded.
Test ran after doing a auto update thru the UI and no factory reset.
Running Speed Test...
BPS=444,701,936
0: 56,719,523 (453,756,184 bps)
1: 55,807,149 (446,457,192 bps)
2: 56,496,749 (451,973,992 bps)
3: 58,399,658 (467,197,264 bps)
4: 55,946,933 (447,575,464 bps)
5: 57,191,873 (457,534,984 bps)
6: 58,758,811 (470,070,488 bps)
7: 55,468,591 (443,748,728 bps)
8: 51,381,228 (411,049,824 bps)
9: 55,574,400 (444,595,200 bps)
10: 55,914,657 (447,317,256 bps)
11: 59,646,114 (477,168,912 bps)
12: 55,303,074 (442,424,592 bps)
13: 51,336,224 (410,689,792 bps)
14: 50,636,556 (405,092,448 bps)
15: 56,181,480 (449,451,840 bps)
16: 55,683,996 (445,471,968 bps)
17: 59,137,625 (473,101,000 bps)
18: 55,705,038 (445,640,304 bps)
19: 51,596,868 (412,774,944 bps)
2nd and subsequent runs...
BPS=358,330,104
0: 41,503,807 (332,030,456 bps)
1: 42,078,387 (336,627,096 bps)
2: 50,804,534 (406,436,272 bps)
3: 57,575,295 (460,602,360 bps)
4: 43,545,600 (348,364,800 bps)
5: 43,661,983 (349,295,864 bps)
6: 43,657,287 (349,258,296 bps)
7: 43,880,868 (351,046,944 bps)
8: 44,011,425 (352,091,400 bps)
9: 44,661,755 (357,294,040 bps)
10: 44,181,916 (353,455,328 bps)
11: 44,165,794 (353,326,352 bps)
12: 44,149,986 (353,199,888 bps)
13: 43,717,175 (349,737,400 bps)
14: 43,639,697 (349,117,576 bps)
15: 43,318,572 (346,548,576 bps)
16: 43,320,026 (346,560,208 bps)
17: 43,791,221 (350,329,768 bps)
18: 43,490,583 (347,924,664 bps)
19: 43,382,087 (347,056,696 bps)
BPS=342,969,568
0: 41,468,825 (331,750,600 bps)
1: 41,248,178 (329,985,424 bps)
2: 40,971,049 (327,768,392 bps)
3: 42,278,189 (338,225,512 bps)
4: 42,029,544 (336,236,352 bps)
5: 41,905,525 (335,244,200 bps)
6: 42,788,585 (342,308,680 bps)
7: 42,709,090 (341,672,720 bps)
8: 43,829,330 (350,634,640 bps)
9: 43,682,628 (349,461,024 bps)
10: 43,081,368 (344,650,944 bps)
11: 41,861,460 (334,891,680 bps)
12: 41,978,212 (335,825,696 bps)
13: 43,190,798 (345,526,384 bps)
14: 43,344,642 (346,757,136 bps)
15: 43,325,433 (346,603,464 bps)
16: 43,310,282 (346,482,256 bps)
17: 44,461,247 (355,689,976 bps)
18: 44,255,468 (354,043,744 bps)
19: 44,301,693 (354,413,544 bps)
BPS=244,102,568
0: 30,532,960 (244,263,680 bps)
1: 32,165,764 (257,326,112 bps)
2: 31,097,598 (248,780,784 bps)
3: 26,976,041 (215,808,328 bps)
4: 26,722,333 (213,778,664 bps)
5: 26,745,762 (213,966,096 bps)
6: 32,088,906 (256,711,248 bps)
7: 31,448,103 (251,584,824 bps)
8: 30,871,822 (246,974,576 bps)
9: 30,790,187 (246,321,496 bps)
10: 30,733,385 (245,867,080 bps)
11: 31,913,807 (255,310,456 bps)
12: 31,517,094 (252,136,752 bps)
13: 30,134,621 (241,076,968 bps)
14: 29,152,885 (233,223,080 bps)
15: 30,829,294 (246,634,352 bps)
16: 32,539,374 (260,314,992 bps)
17: 31,835,401 (254,683,208 bps)
18: 31,162,035 (249,296,280 bps)
19: 31,031,438 (248,251,504 bps)
BPS=342,365,432
0: 37,582,619 (300,660,952 bps)
1: 38,477,507 (307,820,056 bps)
2: 42,505,843 (340,046,744 bps)
3: 42,412,946 (339,303,568 bps)
4: 41,878,725 (335,029,800 bps)
5: 43,137,282 (345,098,256 bps)
6: 43,695,472 (349,563,776 bps)
7: 43,154,726 (345,237,808 bps)
8: 44,239,320 (353,914,560 bps)
9: 43,521,795 (348,174,360 bps)
10: 43,457,467 (347,659,736 bps)
11: 43,595,542 (348,764,336 bps)
12: 43,776,916 (350,215,328 bps)
13: 43,121,249 (344,969,992 bps)
14: 44,404,064 (355,232,512 bps)
15: 41,589,439 (332,715,512 bps)
16: 41,186,681 (329,493,448 bps)
17: 41,226,728 (329,813,824 bps)
18: 43,291,839 (346,334,712 bps)
19: 44,446,588 (355,572,704 bps)
BPS=459,901,816
0: 57,834,393 (462,675,144 bps)
1: 57,981,996 (463,855,968 bps)
2: 57,066,015 (456,528,120 bps)
3: 55,138,301 (441,106,408 bps)
4: 59,563,045 (476,504,360 bps)
5: 58,309,218 (466,473,744 bps)
6: 58,660,583 (469,284,664 bps)
7: 57,616,593 (460,932,744 bps)
8: 49,899,292 (399,194,336 bps)
9: 56,053,203 (448,425,624 bps)
10: 58,125,860 (465,006,880 bps)
11: 58,490,265 (467,922,120 bps)
12: 60,624,956 (484,999,648 bps)
13: 53,097,930 (424,783,440 bps)
14: 56,435,016 (451,480,128 bps)
15: 59,065,738 (472,525,904 bps)
16: 57,856,954 (462,855,632 bps)
17: 61,294,991 (490,359,928 bps)
18: 57,765,120 (462,120,960 bps)
19: 59,236,032 (473,888,256 bps)
BPS=344,107,224
0: 41,714,758 (333,718,064 bps)
1: 41,061,118 (328,488,944 bps)
2: 38,979,347 (311,834,776 bps)
3: 42,238,923 (337,911,384 bps)
4: 43,677,491 (349,419,928 bps)
5: 44,017,626 (352,141,008 bps)
6: 43,862,165 (350,897,320 bps)
7: 43,318,584 (346,548,672 bps)
8: 43,228,835 (345,830,680 bps)
9: 43,485,716 (347,885,728 bps)
10: 43,204,515 (345,636,120 bps)
11: 43,143,916 (345,151,328 bps)
12: 43,285,930 (346,287,440 bps)
13: 41,040,425 (328,323,400 bps)
14: 44,139,230 (353,113,840 bps)
15: 43,805,180 (350,441,440 bps)
16: 44,025,267 (352,202,136 bps)
17: 43,863,365 (350,906,920 bps)
18: 43,804,698 (350,437,584 bps)
19: 43,071,603 (344,572,824 bps)
BPS=463,154,384
0: 59,242,530 (473,940,240 bps)
1: 56,611,267 (452,890,136 bps)
2: 55,244,166 (441,953,328 bps)
3: 52,090,510 (416,724,080 bps)
4: 55,420,047 (443,360,376 bps)
5: 61,431,160 (491,449,280 bps)
6: 58,094,857 (464,758,856 bps)
7: 60,153,264 (481,226,112 bps)
8: 59,419,721 (475,357,768 bps)
9: 54,659,666 (437,277,328 bps)
10: 62,184,951 (497,479,608 bps)
11: 55,026,739 (440,213,912 bps)
12: 54,060,906 (432,487,248 bps)
13: 60,797,037 (486,376,296 bps)
14: 57,881,235 (463,049,880 bps)
15: 62,289,635 (498,317,080 bps)
16: 58,366,493 (466,931,944 bps)
17: 61,514,159 (492,113,272 bps)
18: 59,571,976 (476,575,808 bps)
19: 55,174,320 (441,394,560 bps)
BPS=249,507,152
0: 31,187,203 (249,497,624 bps)
1: 31,275,574 (250,204,592 bps)
2: 32,155,286 (257,242,288 bps)
3: 31,023,572 (248,188,576 bps)
4: 31,059,283 (248,474,264 bps)
5: 31,493,119 (251,944,952 bps)
6: 32,463,408 (259,707,264 bps)
7: 32,189,268 (257,514,144 bps)
8: 31,526,441 (252,211,528 bps)
9: 30,964,876 (247,719,008 bps)
10: 29,793,257 (238,346,056 bps)
11: 32,216,425 (257,731,400 bps)
12: 29,948,398 (239,587,184 bps)
13: 26,695,558 (213,564,464 bps)
14: 31,422,882 (251,383,056 bps)
15: 31,350,230 (250,801,840 bps)
16: 32,564,295 (260,514,360 bps)
17: 31,966,829 (255,734,632 bps)
18: 31,368,502 (250,948,016 bps)
19: 31,079,003 (248,632,024 bps)
Seeing better results than on prior versions of FW. Still not seeing anything near 900Mbps if Orbi is supposed to support 900Mbps.
I'll do a factory reset on the RBR50 and re-test.
