Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
clammerds
Jul 04, 2019Apprentice
I'd be interested in NG's response here.
To be honest, if there *is* an issue, as long as it's resolved within a reasonable time frame, I'm happy.
Blanca_O
Jul 16, 2019NETGEAR Employee Retired
Hi clammerds
Please describe your network setup. What is the expected speed and the actual speed you're getting? Do you have Circle and/or Armor enabled? If so, do you get the same speedtest result if it is disabled?
Blanca
Community Team
- christobevii3Jul 16, 2019Aspirant
Are you using a flat network cable? I'm getting 573Mbs down and 37Mbs upload on mine with cox gigablast. I haven't tested without the router but seems pretty decent and using a Motorolla MB8600 modem
