Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
UeO
Aug 06, 2019Tutor
Additional test:
For this test the RBR50 has been set into router mode. No activation of Circle or Armor.
The temporary setup is Fiber (1000Mb/1000Mb)>Fritzbox 5490 (router mode, no WiFI)>RBK53 (ROUTER mode, daisy off, v2.3.5.30, wireless backhaul).
As before the tests are done at a "quiet moment" nothing turned off or disconnected except for the testing PC. So the results are an indication not an absolute number. And with double NAT (Fritzbox and Orbi are in different subnets).
Download/ upload speeds Fritzbox>RBR50 (Cable cat 5e)>PC (cable Cat5e) in Mbps:
873/771 via speedtestcustom.com
870/740 via fast.com
807/606 via dslreports.com/speedtest
- FURRYe38Aug 06, 2019Guru - Experienced User
Can you configure the Fritzbox for bridge mode or if not, use the DMZ on the Fritzbox?
Test is in a double NAT condition. Not ideal.
Glad your seeing closer to 900Mbps.
UeO wrote:Additional test:
