Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
UeO
Aug 06, 2019Tutor
2nd Additional test:
For this test the RBR50 has been set into router mode and is configured (in the Fritzbox) as exposed host. No activation of Circle or Armor.
The temporary setup is Fiber (1000Mb/1000Mb)>Fritzbox 5490 (router mode, no WiFI)>RBK53 (ROUTER mode, daisy off, v2.3.5.30, wireless backhaul).
As before the tests are done at a "quiet moment" nothing turned off or disconnected except for the testing PC. So the results are an indication not an absolute number.
Download/ upload speeds Fritzbox>RBR50 (Cable cat 5e)>PC (cable Cat5e) in Mbps:
846/851 via speedtestcustom.com
940/800 via fast.com
841/674 via dslreports.com/speedtest
Aug 07, 2019Guru - Experienced User
Thanks for confirming your testing configuration. Seems like your RBR50 is getting near 900Mbps...
Would like to know why some do and some don't. :smileyfrustrated:
