Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
Nov 02, 2019Guru - Experienced User
THanks for your detailed information and test results. This is what i'm seeing as well. Something on the WAN to LAN is being limted. Either QoS is doing this or HW accelleration is not being fully engaged on the RBR.
Have you opened a support ticket here? Please do so as to let NG know about this. The more we make noise, hopefully NG will get it fixed.
https://www.netgear.com/mynetgear/registration/login.aspx
j1simon
Nov 03, 2019Guide
FURRYe38 wrote:Have you opened a support ticket here? Please do so as to let NG know about this. The more we make noise, hopefully NG will get it fixed.
As more than 90 days have passed since the purchase does not let me open a ticket for technical support. :smileymad: (another reason to not buy a Netgear product again).
If they don't fix it before the end of this month I think I'll take advantage of Black Friday to buy a Zyxel Multi X (with almost the same hardware as the Orbi).
When you talk about hardware acceleration, what do you mean?
- FURRYe38Nov 03, 2019Guru - Experienced User
You can contact the forum moderators and ask them about this..
- TimsterNov 04, 2019Aspirant
Hello everybody,
I have XFinity Gigabit and the same issue:
Xfinity > CM1200 > RBR50
Speed in RBR50 (per "integrated" speed test ~950Mbps
Speed on PC (hardwired) ~ 500Mbps
Interested in a solution as well
- FURRYe38Nov 04, 2019Guru - Experienced User
Please contact the forum moderators and ask them about this...
Timster wrote:Hello everybody,
- KringelNov 05, 2019Tutor
Hi,
Just to give this post also my attention.
Seems I'm having exactly the same issue. Did not noticed this before as I only had a 300mb line, but since I upgraded to 1gig line, i'm also having this issue that download spead through orbi is only about ~450mbps while getting ~970mbps when directly connected my PC to the ISP-modem.
Best regards,
Severin
- SW_Nov 05, 2019Prodigy
Recently switched my Orbi setup from AP to Router Mode. I also have Xfinity Gigabit plan. A couple of quick speed tests from various sites show similar results, ~800Mbps-900Mbps over LAN client. Not sure if it makes any difference, but I ticked "Disabled SIP ALG" and select "Open" instead of "Secured" NAT Filtering. YMMV.
See attached file.
- FURRYe38Nov 05, 2019Guru - Experienced User
Thanks for posting this SW_ I'll check these settings out with my RBR50 and see if this changes anything for me.
SW_ wrote:
Recently switched my Orbi setup from AP to Router Mode. I also have Xfinity Gigabit plan. A couple of quick speed tests from various sites show similar results, ~800Mbps-900Mbps over LAN client. Not sure if it makes any difference, but I ticked "Disabled SIP ALG" and select "Open" instead of "Secured" NAT Filtering. YMMV. - FURRYe38Nov 05, 2019Guru - Experienced User
I gave this a try, factory reset and setup from scratch, disabled SIP ALG and selected OPEN For NAT filter. RBR50 still doesn't see much over 400Mbps. Tried two different PCs aswell. Maybe this might work for some.
SW_ wrote:Recently switched my Orbi setup from AP to Router Mode. I also have Xfinity Gigabit plan. A couple of quick speed tests from various sites show similar results, ~800Mbps-900Mbps over LAN client. Not sure if it makes any difference, but I ticked "Disabled SIP ALG" and select "Open" instead of "Secured" NAT Filtering. YMMV.
See attached file.
- FURRYe38Nov 17, 2019Guru - Experienced User
So I wanted to try something with my RBR50 and see if it would even see anything near 900Mbps WAN to LAN behind another RBR with actual live 1G ISP services that I just got activated Friday.
1Gb/50Mbps: CM1100>RBR850 router mode><DMZ for RBR50 router mode>Wired PC
And i'm seeing just over 700Mbps with Ooklas speed test app in Windows 10x64 on the RBR50 in router mode WAN to LAN:
Something I haven't seen with just the RBR50 between two Gb LAN PCs and a switch testing internal iPerf speed testing.
Makes me wonder if HW NAT accelleration or Cut-Through detection is not detecting correctly or operating correctly.
I've got to find time to put the RBR50 online behind the CM1100 directly and see what happens.
- FURRYe38Nov 21, 2019Guru - Experienced User
Ok, so I connected my RBR50 to WAN port #2 on my CM1100 cable modem. RBR50 is on WAN port #1. 1Gb/50Mbps
RBR50 is seeing near 900Mbps with my wired PC speed testing thru the RBR50 using Ooklas installable speed test app in windows 10: Orbi FW v40
Makes me wonder if type of modem or something in the RBRs detection of modems on the WAN side and such could be playing a roll in this. If I take the RBR50 and test it alone with just two PCs and a Gb switch, the RBR50 won't see anything much over 400Mbps. Seems like the RBR50's detection on the WAN side maybe a factor here.
So for this test, the RBR50 connected to a CM1100 cable modem is seeing near 900Mbps.
- j1simonDec 13, 2019Guide
Netgear technical support opened an issue more than 1 month ago for this problem but they haven't solved anything yet, or at least they haven't contacted me again. So I have solved it in a different way.
I took advantage of the fact that the product was still under warranty to return it to the shop as defective and they gave me my money back. With that money, and taking advantage of Black Friday, I have bought another wifi mesh router (of another brand obviously) that works as it should and has more features.Bye bye Netgear!
- FURRYe38Dec 13, 2019Guru - Experienced User
Good Luck.
- SW_Dec 13, 2019Prodigy
j1simon wrote:...
With that money, and taking advantage of Black Friday, I have bought another wifi mesh router (of another brand obviously) that ...
Congrat on your new mesh!
I also took advantage of Black Friday and got 2nd RBK53S from Costco for $300 bucks, which is more economical than a single outdoor Satellite RBS50Y. I also looked at the new Google WiFi set, but it doesn't have any Ethernet port, which is a non-starter for me.
Can you share which mesh you opted to go with?
- SW_Jan 03, 2020Prodigy
With the latest firmware v2.5.1.8, Orbi is able to hit ~900Mbps in AP Mode or ~700Mbps in Router Mode.
Wireless backhaul is around 400Mbps-500Mbps:
- KringelJan 08, 2020Tutor
Thanks for your information.
I can also confirm that with the new firmware (V2.5.0.108) installed it is working much better. I'm getting a much higher speed (~900Mpbs).
- ISST107Mar 07, 2020Tutor
Good Morning: I am running the RBK53S-100NAS from (Costco) (Firmware V2.5.1.8) on a Macbook Air (Catalina OS) everything is updated. I had ATT Fiber 300 Msps and I could easily get ~ 350 down and ~350 up using the Orbi on Wifi. I ugraded to ATT Fiber 1000 and using the Orbi in the Router mode, I can only get ~ 380 down and ~ 400 max up. I called Netgear supprt (2.5 hrs on the phone) and they said I should be getting ~ 500 Mbps down and up via Wifi. Hardwired I am close to 850 -900 Mbps. Should I return this router and try another brand?
I changed the 5GHz channel (i think from 44 to 42) and now my wifi speeds are 362 and 460 so that's a bit better. Still not close to 500+ as I was told. Thanks
