Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
SW_
Nov 05, 2019Prodigy
Timster wrote:Hello everybody,
I have XFinity Gigabit and the same issue:
Xfinity > CM1200 > RBR50
Speed in RBR50 (per "integrated" speed test ~950Mbps
Speed on PC (hardwired) ~ 500Mbps
Interested in a solution as well
Recently switched my Orbi setup from AP to Router Mode. I also have Xfinity Gigabit plan. A couple of quick speed tests from various sites show similar results, ~800Mbps-900Mbps over LAN client. Not sure if it makes any difference, but I ticked "Disabled SIP ALG" and select "Open" instead of "Secured" NAT Filtering. YMMV.
See attached file.
Nov 05, 2019Guru - Experienced User
Thanks for posting this SW_ I'll check these settings out with my RBR50 and see if this changes anything for me.
SW_ wrote:Recently switched my Orbi setup from AP to Router Mode. I also have Xfinity Gigabit plan. A couple of quick speed tests from various sites show similar results, ~800Mbps-900Mbps over LAN client. Not sure if it makes any difference, but I ticked "Disabled SIP ALG" and select "Open" instead of "Secured" NAT Filtering. YMMV.
