Jul 04, 2019Guru - Experienced User
Orbi RBR50 is not supporting 900Mb+- on the WAN to LAN test
So I'd like to call NG's attention to the following test results for Orbi RBR50. I'm not seeing anything near 900mbps on the WAN to LAN test. Using both iPerf and Duckwares simple WAN to LAN test pro...
Nov 21, 2019Guru - Experienced User
Ok, so I connected my RBR50 to WAN port #2 on my CM1100 cable modem. RBR50 is on WAN port #1. 1Gb/50Mbps
RBR50 is seeing near 900Mbps with my wired PC speed testing thru the RBR50 using Ooklas installable speed test app in windows 10: Orbi FW v40
Makes me wonder if type of modem or something in the RBRs detection of modems on the WAN side and such could be playing a roll in this. If I take the RBR50 and test it alone with just two PCs and a Gb switch, the RBR50 won't see anything much over 400Mbps. Seems like the RBR50's detection on the WAN side maybe a factor here.
So for this test, the RBR50 connected to a CM1100 cable modem is seeing near 900Mbps.
j1simon
Dec 13, 2019Guide
Netgear technical support opened an issue more than 1 month ago for this problem but they haven't solved anything yet, or at least they haven't contacted me again. So I have solved it in a different way.
I took advantage of the fact that the product was still under warranty to return it to the shop as defective and they gave me my money back. With that money, and taking advantage of Black Friday, I have bought another wifi mesh router (of another brand obviously) that works as it should and has more features.
Bye bye Netgear!
- FURRYe38Dec 13, 2019Guru - Experienced User
Good Luck.
- SW_Dec 13, 2019Prodigy
j1simon wrote:...
With that money, and taking advantage of Black Friday, I have bought another wifi mesh router (of another brand obviously) that ...
Congrat on your new mesh!
I also took advantage of Black Friday and got 2nd RBK53S from Costco for $300 bucks, which is more economical than a single outdoor Satellite RBS50Y. I also looked at the new Google WiFi set, but it doesn't have any Ethernet port, which is a non-starter for me.
Can you share which mesh you opted to go with?
- SW_Jan 03, 2020Prodigy
With the latest firmware v2.5.1.8, Orbi is able to hit ~900Mbps in AP Mode or ~700Mbps in Router Mode.
Wireless backhaul is around 400Mbps-500Mbps:
- KringelJan 08, 2020Tutor
Thanks for your information.
I can also confirm that with the new firmware (V2.5.0.108) installed it is working much better. I'm getting a much higher speed (~900Mpbs).
- ISST107Mar 07, 2020Tutor
Good Morning: I am running the RBK53S-100NAS from (Costco) (Firmware V2.5.1.8) on a Macbook Air (Catalina OS) everything is updated. I had ATT Fiber 300 Msps and I could easily get ~ 350 down and ~350 up using the Orbi on Wifi. I ugraded to ATT Fiber 1000 and using the Orbi in the Router mode, I can only get ~ 380 down and ~ 400 max up. I called Netgear supprt (2.5 hrs on the phone) and they said I should be getting ~ 500 Mbps down and up via Wifi. Hardwired I am close to 850 -900 Mbps. Should I return this router and try another brand?
I changed the 5GHz channel (i think from 44 to 42) and now my wifi speeds are 362 and 460 so that's a bit better. Still not close to 500+ as I was told. Thanks
