aravind_eee203
Apr 01, 2021Guide
Orbi RBR50 is pink, but satellite doesn't show any light
Hi, My Orbi RBR50 router has pink light, but satellite doesn't show any light and internet is working fine. How can i get rid of the pink light on router and what it means to have the pink light?...
Apr 01, 2021Guru - Experienced User
Has a power off for 1 minute then back ON with the ISP modem and Orbi system been performed since last update?
aravind_eee203
Apr 01, 2021Guide
I have been using for couple of weeks and its this morning i noticed the pink light on router but not on satellite. I am using my own Netgear C6300 cable modem wired to Orbi router. We didn't have any power outages last night and also internet is working fine with the pink light on it
- FURRYe38Apr 01, 2021Guru - Experienced User
What mode is the C series modem in? Bridge or Router? This modem has a built in router and wifi...
- aravind_eee203Apr 01, 2021Guide
I am quite not sure, but i guess its in bridge mode. As i have that C6300 connected to router using ethernet cable and i have wi-fi signal coming from both Orbi as well as C6300.
- vajimApr 01, 2021Master
aravind_eee203 wrote:I am quite not sure, but i guess its in bridge mode. As i have that C6300 connected to router using ethernet cable and i have wi-fi signal coming from both Orbi as well as C6300.
