aravind_eee203
Apr 01, 2021Guide
Orbi RBR50 is pink, but satellite doesn't show any light
Hi, My Orbi RBR50 router has pink light, but satellite doesn't show any light and internet is working fine. How can i get rid of the pink light on router and what it means to have the pink light?...
aravind_eee203
Apr 01, 2021Guide
I have been using it for a while and its this morning i noticed the pink light on router but not satellite. Nothing has changed interms of connection nor any power interruptions
vajim
Apr 01, 2021Master
aravind_eee203 wrote:I have been using it for a while and its this morning i noticed the pink light on router but not satellite. Nothing has changed interms of connection nor any power interruptions
are you able to confirm your firmware?
- aravind_eee203Apr 01, 2021Guide
If i launch the Orbi app on my phone it tries to detect product and says Router not supported, but it was working fine before this pink light. Also if i try to connect to www.orbilogin.com or www.orbilogin.net its auto directing to netgear.com. I tried using IP address 192.168.1.1 as well. Not sure if there is another way
- FURRYe38Apr 01, 2021Guru - Experienced User
Check the user manual for the C series modem on operation modes. There maybe a Router or Bridge or NAT mode some place that needs to be disabled.
aravind_eee203 wrote:If i launch the Orbi app on my phone it tries to detect product and says Router not supported, but it was working fine before this pink light. Also if i try to connect to www.orbilogin.com or www.orbilogin.net its auto directing to netgear.com. I tried using IP address 192.168.1.1 as well. Not sure if there is another way
Sure. But how can that change overnight when none of the connections are touched. It was conected the way its now and working all these days.
