robbiee23
Aug 02, 2019Follower
orbi rbr50 is solid magenta
my orbing is showing a solid magenta halo but I'm still receiving wifi Also I have 2 satellites are connected but one is showing a amber dot when viewing it on the app
Aug 02, 2019Guru - Experienced User
What Firmware is currently loaded on the RBR and RBS?
Is the Orbi system operating in Router or AP mode?
What is the distance between the router and satellite(s)? 30 feet is recommended in between them to begin with depending upon building materials when wirelessly connected.
Armor, Circle, Daisy Chain, Fast Roaming, IPv6 and Set 20/40Mhz Coexistence to 40Mhz only. Save settings and reboot the router and satellite(s).
