Jwa30_11-1
Jul 12, 2020Aspirant
Orbi RBR50 Issue connecting to wifi (Router + Satellite) Modem Netgear CM700
Netgear Orbi AC3000 Home Wifi System Netgear CM700 Modem MacBook Pro (Retina 15-in, Mid 2015) running MacOS Catalina Bedroom The issue I am currently having is the Orbi system doesn't seem to ...
Jul 13, 2020Guru - Experienced User
Try enabling Beamforming and MIMO(MIMO may or may not be needed) and WMM. Under Advanced Tab/Advanced Settings/Wireless Settings
https://community.netgear.com/t5/Orbi/Most-Stable-Orbi-Configuration/m-p/1941087/highlight/true#M97026
Jwa30_11-1 wrote:Netgear Orbi AC3000 Home Wifi System
Netgear CM700 Modem
Bedroom
The issue I am currently having is the Orbi system doesn't seem to appear on wifi. I have tested the modem itself with an ethernet directly to my laptop and it works great so the issue is the Orbi Router not picking up the signal that is being passed through the ethernet. I have also run multiple test from the Netgear guide but have not been succesful. The Orbi light is a solid magenta. Can anyone get me in contact with customer support so I can get a replacement I am still under warranty. I am using my other router ( Nighthawk X6 ) as a backup and it works and runs smooth.
